Out of place restore from save-as script not working
  • 11 November 2021
  • 233 views
Badge +1
Hello community,
I am testing a CLI (qoperation) restore script to restore a random file from clientA to clientB, but it is not working.  The script is getting the following error on the qoperation cmd for the restore XML file:
Out of place restore. User [{clientB}_localadmin__] must have [Out-of-Place Recover] capability for the source and [In Place Recover] capability at the destination.
Anyone have any idea why I’d get this message?
The script is being executed on clientB, but I also get same error running it directly on clientA, the host where the source file lives.
To create the restore script, I used the java console to select clientA/subclient and a specific backup date, then selected a sample file to restore and filled in the restore dialog as a re-directed restore to clientB - then saved the restore script (save-as-script).  I can certainly restore the file if I were to just let the restore run directly from the restore dialog, but for some reason the save-as script is not able to run the XML file.  Seems bizzare, and I’ve not found any setting that controls out-of-place restores, or any BOL page that might explain this.  Maybe I’ve not looked hard enough, but if there is such a setting, why would it be allowed through the console interfaces but not via the ‘Q’ commands?
Thanks in advance for any feedback.
/steve
Best answer by S Green 11 November 2021, 18:51
Badge +1
Bah, nevermind .. I think I know what the problem is here.
Carry on ..
Nice work catching it on your side!
Can you share the solution for posterity?  Also want to be sure you DID find the solution and are up and running.
Gentle follow up on this.  Can you share the solution you found?
