Overwrite Protect Media Group
  • 28 November 2022
  • 321 views
Badge +12
Hi
If media is moved to this group, are there any circumstance where the tape can be written to? with any sort of data
I’d always assumed tape in this group was safe from any form of write
Best answer by Mike Struening RETIRED 30 November 2022, 15:39
Badge +8
No, for writing/data protection jobs, media should only be picked from Default Scratch or a user defined scratch pool
Hey @YYZ , hope all is well!
Tapes in the Overwrite Protect Group should be safe from use, though that’s only to stop that scratch tape from being used as a ‘new’ tape for a write job:
https://documentation.commvault.com/2022e/expert/10414_media_by_groups.html#overwrite-protect-media
From the above link:
The Overwrite Protect Media pool is logical repository for media that should not be used for any write operations. The Overwrite Protect Media pool can be used to save media containing aged data, so that the aged data can be restored if necessary. (See Accessing Aged Data for more information.)
Note that only spare media can be moved to the Overwrite Protect Media pool. If you wish to save data from media in the Assigned Media  pool, use the Prevent Reuse option to automatically move the media to a designated Overwrite Protect media pool when the media is recycled.
Note, however, that the guaranteed way of retaining data is setting the right Data Retention Rules or using the Retain the Job option on the Storage Policy Copy.
Did you see a tape get reused?  If so, to be sure, check the gui audit trail for any changes to that barcode’s status.
Badge +12
Hi Mike
The tape was not an empty scratch tape.
It had been used a few days before. It was only used for a single Storage Policy and an associated  single Copy policy
The tape wasn't full
But had been manually moved to the Overwrite Protect Group (ie from an Assigned Media Group)
The same SP / Copy Policy ran today and has written data to that same tape (while it sits in the Overwrite Protect group)
Here’s the write to the tape - about 5 hours ago
(ignore the IEPOrt location - I exported the tape after I found it was being written to
and here’s inside the tape - just to check what was being written - ie its a modest amount of write
BOL - could be interpreted in many ways
eg
  1. Aged data is ‘safe’ inside the Overwrite Protect Group
  1.  or there’s also an implication that the data on the  Tape was safe - but the system was just adding more data to the tape etc
I suppose the best option would have been to Mark the media full - as all I was trying to achieve was to prevent further data being written to the Tape
I think you have it understood.  The Overwrite Protect group is meant for aged tapes to ensure no one uses them (i.e. wipes them out to start anew).  since your tape was an active media, the effect of the Overwrite Protect group did nothing.
If your use case, marking it as full would have been best, as well as (optionally) using Prevent Reuse.
Let me know if that clears it up!
Badge +12
Mike….Thank you
I’d never placed a ‘non aged’ Tape into the ‘protect’ group before
My eyes 🤓 did a double take when I saw it was being written to.
Fully understood now - I’ll use ‘Mark as Full’ in the future
Happy to help!
