Hello!
I would like to ask about the best processor options for a MediaAgent.
Right now we have followed the MediaAgent hardware requirements from the documentation. So I have a XL MediaAgent with 16 CPU cores.
Backups run just fine except for this big database (more than 100TB) that runs a synthetic full every two days. It takes about 9 hours to finish. Although the customer is happy since the old backup solution would take days for the same result, I would like to know if that time could be improved.
Performance monitoring tells me that the bottleneck is the MediaAgent’s CPU. All 16 cores run at 100% while the synthetic full backup is running. So… I would like to know the following (for this current setup and also for the new MediaAgents that will be added to this CommCell):
- Will adding more cores help? For example, adding a second processor with 16 cores to the current MediaAgent (although it would double the recommended hardware requirements from documentation).
- Or would it be better to get a CPU with higher frequency (same core count)?
- Does it make a difference for the commvault software to have single-processor or dual-processor mediaagents? For example: one 24-core cpu vs two 12-core cpus (same frequencies).
- If adding more processing power, would more RAM (or anything else) be needed even if right now it barely hits 35% usage peaks?
Thanks in advance for the help!
Sergio
