Hi Team,
Is there any way to connect the Physical Tape Device into Virtual Machine under vmware Esxi Host?
The VM will install with Window OS. Is there any possible to do so without physical Media Agent?
Please advise or share any related document.
Appreciate the help to guide, if we can use FC/ SCSI connection to connect both VM & Tape Library.
Best answer by Collin Harper
