PostgreSQL index files restore
  • 25 January 2022
  • 57 views
Badge +12
Hi all
I am running a PostgreSQL restore and the DBA has mentioned that the index files haven’t restored on this particular restore process.
I’m doing a table level restore to another DB instance (out of place).
He mentioned a restore that was completed in December had the index files restored. I’m a bit at a loss as there is no option to allow this from what I can see. I also followed the identical restoration process as was done in December so I’m a little stumped.
Not sure if there is a simple solution to this? I am happy to log a support ticket bu thought I’d ask here first.
Thanks in advance.
Mauro
Best answer by Meera 25 January 2022, 12:43
Badge +7
Hi Mauro,
Are you performing restore from dumpbased backup or block level backup? What is the service pack level of client?
Meera
Badge +12
Hi Meera
I’m doing a dumpbased backup/restore.
I’m on V11.25.14 which was upgraded about 2 weeks ago.
Mauro
Badge +7
Hi Mauro,
Database level or schema level restore restores index also. Table level doesn’t. What was the service pack level in December?
Meera
Badge +12
Hi Mauro,
Meera
That makes more sense now.
We were on V11.25.9 in December.
I’ll just check what we did then and give a quick update.
Badge +12
Hi Mauro,
Meera
Thanks so much.
I’ve tested both options with the results as expected, so I’ve let the DBA know on the difference.
Badge +12
@Meera May I ask a question regarding the table restore that was posted to me by the DBA?
He wanted to find out if the functionality to restore the Indexes during a table level restore are going to be a feature in future releases or is this a PostgreSQL limitation?
Thanks so much.
