Hi Expert,
We have Commvault B&R system which is deployed on top Openstack contain 1 mainsite and several remote site. The mainsite contains Commserve (Windows 2019), Media Agent (RHEL 8.0) and Virtual Server Agent (RHEL 8.0). Remote site contain Media Agent and Virtual Server Agent. The B&R system backup some VM on top of openstack, and backup result saved on separated storage server.
Within next week, we are planning to do delete-create Commserve as part of virtualization activity. There are some question which I want to clarify:
1. During commserve delete-create (new deployment), what commserve part is needed to be backup? and is there any pre-activity we should do (such as terminate remote connection from VSA or MA)?
2. After new commserve succesfully created, we need to re-integrate remote VSA and MA to new commserve. What procedure should be performed in Commcell console to detect the remote VSA and MA?
3. Regarding installed commserve license, can we re-use existing license to use in new commserve VM? and what part should we backup?
Any feedback are highly appreciate
BR,
Mahendra K
Best answer by Stuart Painter
