All my media agents have the same settings in Media Agent → Properties → “General” Tab except one, which has ”Validation on Network” not checked (the others do). I found the docs for this setting here: MediaAgent - Online Help (commvault.com) and its one of those where the definition is basically rewording the setting (not a lot of detail)
Is there any reason anyone would *not* want to check “Validation on Network”? I’m not sure if it was an oversight or done for some reason for this one media agent. I’m mostly sure it was oversight or forgotten about, but wanted to see if “Validation on Network” was something set by default (I’m on SP16), or if people turn it off as its CPU intensive or mostly unnecessary unless you need xyz protection from bad/choppy network connections. I would guess that if “Validation on Network” is unchecked… something else would catch invalid data before its written to disk?
