Remove mount options for InteliSnap
  • 20 January 2023
  • 66 views
Userlevel 1
Badge +7
Trying to mount InteliSnap snapshot from Ubuntu 18 on Ubuntu 20. Filesystem was mounted with nobarrier option, obsolete in Ubuntu 20:
1899337 26ca0b 01/20 14:07:29 ####### DoMount() - DoMount :** System returned  =  32, stderr = mount: /mnt/ble/volume_784_1674219622: wrong fs type, bad option, bad superblock on /dev/mapper/pgdata--oas--vg_copy_001-pgdata--oas--lv, missing codepage or he
lper program, or other error.
  **, running fsck on the device and retrying mount
Any ninja option to fix that? (other than use same version on target system😎 ).
In MA.log there is :
1899337 26ca0b 01/20 14:07:28 ####### GetMountOptionsFilter(10504) - default common skip options [cio] (1)
is there a way to add other parameter to “skip” list?
Best answer by Orazan 23 January 2023, 13:52
Badge +15
Good morning.  Can you please verify if this is a file system snap backup or is this a database backup that you are attempting to mount?
Userlevel 1
Badge +7
Hello. It’s database psql backup.
Badge +15
You would either have to mount to a Linux box which does not have the nobarrier parameter deprecated or your other option is to open a support case.  There possibly is a workaround that Development can provide to assist.
Userlevel 1
Badge +7
I did downgrade, but good to know there is a workaround.
Thanks.
