Sap for Oracle Failed - BR0231E Backup utility call failed
  • 25 July 2022
  • 438 views
Badge +1
Hello everyone,
I have sap for oracle client with oracle version 19 and brtools patch level 47.
Simpana version is V11 SP16.
Before the oracle upgrade I was able to make backups successfully, after the upgrade I always get this error:BR0229I Calling backup utility with function 'backup'...BR0278I Command output of '/usr/sap/MFP/SYS/exe/run/brtools -f newgroup /usr/sap/MFP/SYS/exe/run/backint -u MFP -f backup -i /oracle/MFP/sapbackup/.bfjpvmzu.lst -t file -c':/bin/sh: line 1: 552057 Segmentation fault      (core dumped) ( /usr/sap/MFP/SYS/exe/run/backint -u MFP -f backup -i /oracle/MFP/sapbackup/.bfjpvmzu.lst -t file -c )BR0280I BRBACKUP time stamp: 2022-07-25 19:00:02BR0279E Return code from '/usr/sap/MFP/SYS/exe/run/brtools -f newgroup /usr/sap/MFP/SYS/exe/run/backint -u MFP -f backup -i /oracle/MFP/sapbackup/.bfjpvmzu.lst -t file -c': 139BR0232E 0 of 6 files saved by backup utilityBR0280I BRBACKUP time stamp: 2022-07-25 19:00:02BR0231E Backup utility call failedCan be a problem with brtools patch level?
Best answer by Gowri Shankar 25 July 2022, 23:30
Badge +12
Hi @Sérgio Batalha
Looks like the process is crashing
Could you try running brconnect to check the connection using brtools
su - <orasid / sidadm>
brconnect -u / -c -f check
Also provide the output of
ls -l /usr/sap/MFP/SYS/exe/run/backint
ls -l /opt/commvault
Gowri Shankar
Badge +1
Hello @Gowri Shankar ,
Attached is the result of the brconnect check.
The output:
uii302:mfpadm 429> ls -l /opt/commvault
total 1288
lrwxrwxrwx.  1 root oinstall       6 Jul 18 16:51 Base -> Base64
drwxrwxr-x.  2 root oinstall    4096 Jul 18 16:51 Base32
drwxrwxr-x.  7 root oinstall   16384 Jul 25 14:34 Base64
-rwxrwxr-x.  1 root oinstall     591 Jul 18 16:51 branding
drwxrwxr-x.  3 root oinstall      22 Jul 18 16:51 CVAnalytics
drwxrwxr-x.  3 root oinstall      19 Jul 18 16:51 CVBF
drwxrwxr-x.  2 root oinstall    8192 Jul 18 16:51 CVBLK
lrwxrwxrwx.  1 root oinstall      14 Jul 18 16:51 cvpkgrm -> Base64/cvpkgrm
drwxrwxr-x.  2 root oinstall    4096 Jul 18 16:51 CXBF
drwxrwxr-x.  2 root oinstall    4096 Jul 18 16:51 FSF
-rwxrwxr-x.  1 root oinstall     172 Jul 18 16:51 galaxy_vm
lrwxrwxrwx.  1 root oinstall      12 Jul 18 16:51 iDataAgent -> iDataAgent64
drwxrwxr-x.  3 root oinstall     131 Jul 18 16:51 iDataAgent32
drwxrwxr-x.  6 root oinstall    4096 Jul 18 17:24 iDataAgent64
drwxrwxr-x.  2 root oinstall    4096 Jul 18 17:25 installer
-rwxrwxr-x.  1 root oinstall 1247391 Mar 13  2018 ksh
drwxrwxr-x.  2 root oinstall     226 Jul 18 16:51 QCommand-Samples
drwxrwxr-x. 34 root oinstall    4096 Jul 18 16:51 Updates
uii302:mfpadm 430>
@Sérgio Batalha following up on this one.
Were you able to get this resolved?  I don’t see an incident in your name.
@Sérgio Batalha , following up on this one.
As mentioned by @Gowri Shankar mentioned, it looks like the process crashed.
