We have a two-node SQL-Cluster with 10 SQL-Instances, load-balanced over the nodes.
Currently we fail to set up the backup. Only the instances running on node A are passing the backup successful. Instances on node B are failing with the following error:
[30:332] Description: Unable to get the SQL Version for the server
- installed and check cv-software von slqcn1 and sqlcn2
- added a windows-cluster in commvault and added sqlcn1 an sqlcn2 to this cluster
- added all sql-instances to this windows cluster
Is this correct or do we have to create one cluster for each sql-instance in cv-software?
Best answer by Mike H
