Question: is it possible to add another error code on the same report, for example we send out reports for error id 6:64 but I would also like to include the error code 19:857 on the same report.
Best answer by Mike Struening
View originalHey
Is that correct? I can see if this will be acceptable as a CMR once you confirm.
