Test Net Connection not working on DR CV Node
  • 3 February 2023
  • 29 views
Badge +4
Hi Guys,,,,
We are not able to perform TNC on ports 8400 and 8403 to DR Commserve node.
Is this because the services are stopped on the DR node ? Its a Live-Sync DR configuration.
pank1988
Best answer by Jos Meijer 3 February 2023, 10:44
Badge +16
Hi @pank1988
When the Instance001 services are stopped you cannot communicate on 8400 and 8403 as there is no binding.
Instance002 is online in a CS LiveSync setup and by default has bindings on 8405 and 8408.
