Unable to use disk mount path
  • 1 February 2021
  • 2463 views
Badge +1
Mount path volume is dirty. Please run chkdsk on this volume
Best answer by Damian Andre 1 February 2021, 15:17
Badge +14
Hi Shalika,
Do you see any events in the Application Event Log for those Volumes on the MA Server?
Have you run chkdsk on the Mountpoints for these Mount Paths? - You can get the Volume guid from mountvol, then run a chkdsk against that volume GUID.
Michael
Badge +1
Hi MichaelCapon,
I’m checking on that.
Shalika
Hi MichaelCapon,
Shalika
If NTFS detects issues with the file system it turns on the “dirty” bit which forces a check disk operation next reboot. Commvault detects this as we don’t want to write to a potentially damaged volume and unknowingly put data at risk. You can see more info about the dirty bit and how to turn it ‘off’ here: https://docs.microsoft.com/en-us/windows-server/administration/windows-commands/fsutil-dirty
  • A volume's dirty bit indicates that the file system may be in an inconsistent state. The dirty bit can be set because:
    • The volume is online and it has outstanding changes.
    • Changes were made to the volume and the computer was shut down before the changes were committed to the disk.
    • Corruption was detected on the volume.
  • If the dirty bit is set when the computer restarts, chkdsk runs to verify the file system integrity and to attempt to fix any issues with the volume.
Badge
description: Export / Mount failed for mount path [K:/E29HAA_04.16.2022_09.11/CV_MAGNETIC], please check if the mount path is accessible on Data Server [MHSDC-BKP-SRV3.MAHAGOV.LOCAL]. Check the logs for detailed error. what does it mean
@101c3e , log into MHSDC-BKP-SRV3.MAHAGOV.LOCAL and confirm that K:/E29HAA_04.16.2022_09.11/CV_MAGNETIC is accessible.  the error indicates it is not (or was not at the time of the error).
