Unfortunately due to the way we work some of our colleagues only connect laptops to VPN for a few hours each week at random times. I’ve found many of our laptops with corrupted Commvault agent installations, which I am trying to repair using SCCM. I have tried deploying a job from the Commcell to uninstall or repair, but I’ve not had any luck getting that to connect with these laptops so falling back on SCCM.
The best way I can think of resolving these issues, is to use “setup.exe /uninstall /silent” and then once uninstalled deploy the software again. This is working to remote the software from the laptops I am testing on, but it is not working to retire the laptop in the Commcell/Commserve as the colleagues don’t have permissions on Commcell.
Is there a way to embed credentials into an XML and reference that in the uninstall?
Best answer by christopherlecky
