Hello Commvault Community!
I know there is an option to upgrade the hotfix version locally for the Instance Failover using CMD which doesn’t raise Commvault services.
In addition to the command itself, please let me know if there is anything else we need to consider when upgrading the hotfixes for the Failover Instance.
I will just add that on the Failover server one of the instances already has the correct version, but the one responsible for Failover, unfortunately, doesn’twant to get up and I have to do it via CMD.
Thanks&Regards,
Kamil
Best answer by Brian Bruno
