Hello Commvaunt Community,
I need your opinion and support regarding the backup problem for two virtual machines.
The client claims that after updating the environment to version 11.25.6, he began to observe a performance problem for one VM and the other cannot be backed up.
I went down to the logs and for the task, it contains several VMs (but the problem is with one, the task takes 3 days) I found entries that are looped but I do not know what they can mean.
@MediaAgent6 - VixDiskLib.log
34680 6878 11/22 10:57:41 3185939 VDDK_PhoneHome: VddkVacWriteLastMember : Empty field to serialize for key fail_function at line 271.
34680 6878 11/22 10:57:42 3185939 VDDK_PhoneHome: Curl perform failed in VddkVacCurlHttpsPost with error code 7 at 1780.
34680 6878 11/22 10:57:45 3185939 VDDK_PhoneHome: VddkVacPushData : Failed to post data to VC/PH at line 1719.
@MediaAgent6 - vsbkp.log
34680 67b0 11/23 21:03:28 3185939 CVmdkVcb4ExtentReader::ReadBlockFromReadAheadCache() - Delay while looking for block [144745]
34680 3b68 11/23 21:03:34 3185939 VSBkpController::MonitorProcesses() - Detected that other 5 vsbkp processes now have 3 streams running
34680 8af8 11/23 21:03:43 3185939 VSBkpDatastoreMonitor::ReportDatastore() - Datastore [ESX-DMZ-APP-PROD-DS04] [821,008,793,600] bytes free [12.45%] Update Interval [120] seconds [1] VMs
34680 67b0 11/23 21:03:43 3185939 CVmdkVcb4ExtentReader::ReadBlockFromReadAheadCache() - Delay while looking for block [144745]
34680 3b68 11/23 21:03:44 3185939 VSBkpController::MonitorProcesses() - Detected that other 6 vsbkp processes now have 4 streams running
34680 3b68 11/23 21:03:54 3185939 VSBkpController::MonitorProcesses() - Detected that other 6 vsbkp processes now have 5 streams running
34680 67b0 11/23 21:03:58 3185939 CVmdkVcb4ExtentReader::ReadBlockFromReadAheadCache() - Delay while looking for block [144745]
34680 3b68 11/23 21:04:04 3185939 VSBkpController::MonitorProcesses() - Detected that other 6 vsbkp processes now have 11 streams running
Searching for available articles but they didn't get me on anything interesting.
Do you have any idea what could be causing the problem? If not, it escalates to Commvault support.
Thanks&Regards,
Kamil
Best answer by Kamil
