VSAN / XRAIL integration
  • 17 April 2022
  • 590 views
Badge +2
Hello;
I just need to know more about the integration between Commvault and VXRAIL requirements [Ports, Connectivity] also need to know how the backup works and how the traffic goes using normal backup and IntelliSnap.
thanks
Best answer by Scott Moseman 3 June 2022, 22:55
Badge +16
Hi @Nezar
Here is the building block guide for VMware:
https://documentation.commvault.com/11.24/expert/32799_vmware_building_block_guide_virtual_server_agent_for_vmware.html
General VMware info:
https://documentation.commvault.com/11.24/expert/31993_virtual_server_agent_with_vmware.html
Here you will find the general port requirements for the VSA backup:
https://documentation.commvault.com/11.24/expert/32806_port_requirements.html
Array configuration, select your array in sub menu for specifics:
https://documentation.commvault.com/11.24/expert/33073_supported_storage_arrays.html
General intellisnap information for VXrail;
https://documentation.commvault.com/11.24/expert/62400_intellisnap_protection_for_vms_on_vvol_or_vsanvxrail_datastores.html
Hope this helps 🙂
Badge +2
@Jos Meijer  thanks alot , actually i need to know the backup traffic path [data path] if applicable in case of normal backup or intellisnap backup..
@Nezar , can you clarify what you are looking for?
@Nezar , following up on this one.  Can you clarify what you need?
Badge +18
The backup data will flow from the VxRail to your MAs over the LAN.  You can use either NBD or HotAdd modes.  SAN mode is not available.  You can use IntelliSnap, but realize you don’t get the same benefits as taking snapshots using a traditional storage array.  The Backup Copy jobs will still send data over the LAN since SAN mode is not available.
Scott
