Workflow exports are .TML and not XML?
  • 25 February 2023
  • 30 views
Badge +11
I built a workflo that I would like to deploy on another commcell and its coming down as a .TML instead of a .XML.
I thought maybe i did something wrong- but all the workflows i have built even the built-in ones are exporting like that.
Anyone else having this issue?
Badge +6
From what location or screen or you exporting the workflow from?  Can you send a screenshot of it?
Badge +11
From development>workflows area- which is , To my knowledge, is the only place you can export within the command center. Should I try from the java client?
Badge +11
This does not seem to be normal. Curious to see what happens when i put a ticket in
