Help with powershell Script
  • 14 September 2022
  • 220 views
Badge +13
Hi Team,
I am trying to run the workflow using PowerShell and capture the workflow job id output to the text file, that text file will be read by our BigFix tool.
Below is the scripts and the error i am getting
PS C:\Users\awilliamtell> $jobid = Start-CVWorkflow -name baas_workflow -Force | select jobid
INFO: Start-CVWorkflow: enter inputs for workflow [baas_workflow]
PS C:\Users\awilliamtell> qlist job -cs BTEEGVPCSTVW001.forsythehosting.com -j $jobid -waitForJobComplete -waitTimeoutSe
cs 600 | out-file -filepath c:\test\test.txt -append
job: Error 0x303: Invalid job Id @{jobId=18850}
I tried to print the $jobid and if its giving output as Can't find file @{jobId=18866; processId=18866}
PS C:\Windows\system32> $jobid = Start-CVWorkflow -name baas_workflow -Force
PS C:\Windows\system32> print ($jobid)
Any help will be great!
Best answer by JnaneshD 15 September 2022, 06:05
Badge
Hi Allan,
Print in powershell is done via a command called Write-Host.  The function Print() maybe calling a Printer related function.
Output of the Start-CVWorkflow command is an object which contains jobId and processId. Reference API : https://documentation.commvault.com/11.24/essential/49452_executing_workflow_as_api_rest_api_get.html
We can use it like this
 $output = Start-CVWorkflow -name baas_workflow -Force | select jobid
$jobId = $output.jobId
