Hello Commvault Community,
At the beginning, I will explain the situations that we need to meet with the client.
We have a production environment with several TapeLibraries and a few DiskLibraries. The client decided that he would like to use the newly created, dedicated Scratch Pools, but he wants them to be automated.
This is to work in such a way that for certain Storage Policy copies LTO-7 tape is to be taken or in the second case LTO-8. This configuration is intended to apply to multiple Storage Policy Copies.
We'd rather avoid creating all Storage Policies from scratch. However, we know that the Storage Pool settings define the "Default Scratch Pool" settings, where you cannot select individual ones for each copy and additionally, you cannot change it if the copy is already running and has data saved, but we probably found a workaround for this.
When we create a new copy to tapes, for an existing Storage Policy, we can choose a Storage Pool/ or create new one, there other than the rest of the copies have. However, this is where the main problem arises, because if we want to create a Storage Pool for tapes, it will create and we can create a dedicated Scratch Pool there, but one Storage Pool for tapes = one copy.
Here comes my question, is it possible to make a "Standard Storage Pool" like it used to be? Why am I asking? Because Standard Storage Pool can be selected multiple times for many copies (Dependend Copies), and for Storage Pool for tapes only once, and then you need to create a new one.
Is it possible to create such a Standard Storage Pool or is there any similar workaround for this situation?
I don't know if I have described it clearly enough, but if you need to explain something with screenshots, let me know.
Attached are screenshots with the list of Storage Pool, for better understanding.
Thanks for any help.
Kind Regards
Kamil
Best answer by Kamil
