There is a test VM we created to test the script but it not being fetched while all the other VMs are being fetched
the only difference is test VMs are not added in the domain
Hey @Tasnee,
I don't think its possible to troubleshoot further without additional information. Suggest opening a support case to see if there is an issue with the API or something else preventing your test VM from showing up.
