Instance Enable
  • 26 July 2023
  • 22 views
Badge +1
I am monitoring the subclients. I see the “enableBackup” in the api for the subclients but notice the job does not run when the instance is not enabled which I can detect visually from the UI but do not see an attribute in the Instance or InstanceProperties API. Is there attribute for the instance enabledBackup?
Best answer by Navneet Singh 27 July 2023, 08:54
