looking for sql view or direct sql table
  • 17 July 2023
  • 29 views
Badge +2
to joing 2 simple thing ….i want to see job from particular SP and connected media (tapes) to it ...i have jobs in SP and media ..but how to connect them :)
sub-question is any dictionary with CV tables / views with  info what fields is about ….or better how they are joined as keys between tables ?
Badge +7
@Marcin_CF
Good Day!
You can use the jobs in storage policy copies report to view the jobs and its barcode
https://cloud.commvault.com/webconsole/softwarestore/store.do#!/135/660/26149
Note: “Barcode” column can be added by clicking on settings→ columns
Coming to your second question, there is no directory that displays the tables information.
Instead, you can copy the equivalent API and use them.
Kindly let me know if this helps?
