DataServer-IP on Linux Red Hat requirements - problem with communication
Does the Dataserver-IP feature require any special libraries, packages or customization on Red Hat 9.4? like here:
I have 2 Media Agents and I want to share mount paths (LUNs mounted to each MA). But there are some errors eg. with Data Verification or backup:
Cannot connect to Data Server, please make sure desination MediaAgent is up and running and there is no network / connvectivity issue between source and desination Media Agent.
In NFSTtransport log:
3dfs server @ @cv-ma-g02] failed to start, reason: Services/3dfs are not reachable or refusing connection
There is no firewall between them, there are able to cummunicate, services are running but still problem exists. There is no NFS service installed on this server - should I install it?
Page 1 / 1
Hi @mateusznitka,
To share the Dataserver IP, we need to enable the ports 111,2049 & 2050 to be opened between two media agents. Make sure these ports are opened. Use cvping to check the connection.
If you are able to connect the ports both ways, add below additional settings on primary Media Agents
nMount3Port and nNFS3Port with values 2050 and 2049 respectively.
3dnfs is the service used when Dataserver-IP share is in place. 3DNFS requires NFS-Ganesha packages to run.
You can also check the service of 3dnfs by using cmd: netstat -tulpn | grep 3dnfs
If any RPMs are missing in these MA’s, this service will won’t run. To check if any RPMs missing, do the following, this will show you the missing RPMs, you need to install them and then restart CV services
Navigate to Installation_Directory/Base
Execute: ./3dnfsd -vm InstanceName -cn ClientName
Hope it helps!
Warm Regards,
Sravan Kondeti
Hello @mateusznitka
nfs-utils should be installed on both the MA’s along with rpcbind and make sure they are able to communicate over 2049, 111, 2052.
rpcbind and nfs* packages are installed on rhel 9.4
able to do cvping to port 111 & 2049
firewall is off in all MA and CommServ,
Selinux is in Permissive mode.
backup is getting completed but while restore getting error like: Error Code: g62:2687] Description: Export / Mount failed for mount path [/backupstorage10/6ILYU6_01.03.2025_16.32/CV_MAGNETIC], please check if the mount path is accessible on Data Server vSISHA820G3-47]. Check the logs for detailed error. Source: SISHA820G3-45, Process: cvd “
For those having trouble with DataServer-IP on RHEL 9:
I contacted support, for now the only option is to install RHEL 8 on MA, since there is no Ganesha package for RHEL 9.
This should definitely be in the documentation, because it is confusing now - it says it supports RHEL9, but it turns out that one of the basic features does not work on it.
