Can a second instance of commvault be installed on SQL cluster on windows?
Or are there any known issues with that?
Hi @Sandy11
What is the use case for this? Why do we want to install different instances?
Sunil-
We are setting up a new commcell and existing commcell will be retained for legacy restores.
So need the client to have access to both.
It is controlled by a key. Please raise a ticket with support. We can provide the key.
Sunil
Hi Sunil,
according to books online the Multiinstancing für SQL Server is not supported.
https://documentation.commvault.com/2023e/expert/multi_instance_support_01.html
But … there is a key to overcome this situation?
Regards.
Michael
Yes, support can validate the use case carefully and can provide the override.
This is disabled specifically for SQL since running backups from both instances will result into data loss.
Sunil-
