Hi All,
What can be the best practice for Implementation/Deployment of commvault tool?
Hi All,
Hello
Your question is pretty broad in scope since the Commvault tool comprises the Commserve, the Media Agents, Clients, and a lot more.
If you check our docs, thanks to our super amazing new search engine, you can search for Best Practices and get a ton of results:
This should cover pretty much every aspect of the deployment.
If you have any specific questions, let us know!
i think personally it depends on your needs and also on the size of the environment which you want to backup!
Hope this helps !
