Hi Everyone,
Currently we are making traditional backups from HS to HS (Primary - Secondary Copy).
We added an extra Cloud Library as AGC location as mentioned in the picture below.
Goal
The AGC NEEDS to finish within 24 hours contains File System + SQL Agents that were backed up from the last 24 hours on the Disk Libraries.
Observation
From the {Secondary to AGC} it seems that new bckjobs are not picked up after the aux copy started.
Example: If bckjob 1-4 contains 10TB of data, commvault waits until these ones are finished and then will pick up the next bckjobs while some Media Agents in the Cloud Library are doing less work.
Conclusion
The {Secondary to AGC} takes to much time (+/- 48 hours), after the Full Backups are finished in the weekends on the Disk Libraries. It does NOT meet the requirements.
Questions
1. Are my observations correct if yes, how to tune it?
2. Any other options to meet the requirements?
