I’ve needed to delete - create again the DDB and I need to use same partition paths as they were used before (disk was formatted). Currently I cannot create a DDB as I have message:
“The specified mount path os already in use”
Well I know that it’s described here:
http://kb.commvault.com/DD0051
But do you know somebody if there is way to force cleanup and do not wait 24h ? The data aging is not doing the trick.
Best answer by Prasad Nara
