We originally purchased 83TB for File & Object Storage. We originally had 12 file servers on a plan that was “daily for 30, and monthly for 365 days”.
We are currently decommissioning all file servers (5 so far) and have migrated to Object Storage with Azure Storage Accounts. This is duplicating our storage quota, and we have now exceeded our purchased 83TB’s by 141% with File & Object Storage sitting at 116.3TB.
So, currently with the 5 serves that are offline, I have unassociated the plan, and set the Server to not back up, and retired the server. But this will hold the backups till the retention period of 365days is met, then the data will delete. We are also holding onto the SAN and the old servers encase we need to powerup and access a server in a worst-case scenario for the year.
If I delete the server, then all the data in retention will be deleted as well. and we want to be able to restore anything if we come across a file problem.
Is there a way to reduce or delete the amount of monthly’s that are retained, and just keep one month for the 365day retention period and let it attrition out?
Or can we move the retired data to cold storage or something to cut down on Usage or costs?
