License consumption by virtaul machines
  • 18 June 2024
  • 33 views
Userlevel 1
Badge +6
If a VM is being backed-up ( VSA backup ) from 2 different backup-sets using the same storage pool, is there any impact on the license consumed by this VM ? will there be a double ‘charge’ for it - per Front-End ( capacity license ) ?
Best answer by HolowEd 24 June 2024, 14:44
Userlevel 5
Badge +12
@TNO ,
Being you are talking about Capacity, yes there could be the chance that you are seeing it twice; To confirm you would need to check the subclient that is backing up the VM and see what is recorded for it Front End. I would expect you to see the size of the VM counted by each subclient.
Edward J Holowienka
Userlevel 1
Badge +6
Thanks @HolowEd
you would need to check the subclient that is backing up the VM and see what is recorded for it Front End -  you mean chargeback report ?
Userlevel 5
Badge +12
@TNO ,
No, if you are using Commcell Console run a Job Summary report for the 2 subclients and see what the application size is. If using Command Center, run the Backup Job Summary report and look for the same information.
Edward J Holowienka
