Backup Exchange - configuration
  • 10 November 2021
  • 19 replies
  • 271 views
Userlevel 2
Badge +11
we have a problem with CommVault and the backup of our Exchange, which rather boils down to incorrect / incomplete backup configuration.
CommCell ID: 1012ff
Version: 11.22.36
We have Exchange 2016 (on premise) or the entire DAG for backup.
DAG consists of 4 Exchange servers based on Nutanix (AHV), in 2 clusters.
Current CV configuration:
2 DAG nodes per cluster, assigned to Data Protection EX-AD-CH2 and EX-AD-CH3:
When you try to restore, you can see that something has been bought back:
Only with this approach we backup the entire VMke in the form of a snapshot - this approach is not recommended by MS in the case of Exchange.
Additionally, the job ended with an error - it was not possible to mute the system files:
In addition, I added a new client - Exchange DAG - with an indication of our group:
At the same time, this one does not see nodes, so I bet that I have not set something up yet.
Backup configuration questions:
What is the correct approach to Exchange backup using CommVault in our case?
Exchange does not seem to support snapshots, or is not recommended:
„Some hypervisors include features for taking snapshots of virtual machines. Virtual machine snapshots capture the state of a virtual machine while it's running. This feature enables you to take multiple snapshots of a virtual machine and then revert the virtual machine to any of the previous states by applying a snapshot to the virtual machine. However, virtual machine snapshots aren't application aware, and using them can have unintended and unexpected consequences for a server application that maintains state data, such as Exchange. As a result, making virtual machine snapshots of an Exchange guest virtual machine isn't supported.”
https://docs.microsoft.com/en-us/Exchange/plan-and-deploy/virtualization?view=exchserver-2019
Please help with the correct configuration of the backup.
Best answer by JamesA 10 November 2021, 12:10
Userlevel 2
Badge +5
Hi @kszaf
Thank you for your post. The nodes of the DAG should be listed on the properties of the client under Advanced > Database Member Servers.
This is an example from within my lab:
In order to see the nodes or be able to discover them if they are not present there needs to be two main things done:
  1. ​​​​​​​The Commvault Exchange package needs to be installed on all member nodes in the DAG
  2. The “Host Name” of the Exchange client members need to be the FQDN
For example:
More details can be found in documentation on this:
https://documentation.commvault.com/11.24/expert/17022_creating_exchange_dag_client.html
Let me know if you have any other questions on this.
Badge +6
@kszaf
As for the question here:
This is related to snapshot of the VM itself. MS does not recommend relying on the VM snap to protect the Exchange data. You should be leveraging the Exchange database (DAG client in your screenshots) to protect the Exchange database data, truncate the logs, etc.
Were you able to confirm the nodes configured on the DAG properties → member servers?
Userlevel 2
Badge +11
@JamesA
For the last few days I tried to run a backup according to the instructions, but it crashes immediately on the installation of the Commvault Exchange package.
Unfortunately, I have no idea what could be wrong and I would need further help on this topic …
Below I show what I was doing and what the effect is:
Commcell -> Tools -> Add / Remove Software -> Install Software
For example, one of the target 4 Exchange servers has been added:
Selected Exchange Package:
The rest of the installation settings are standard.
Installation job ends with error:
It looks like I'm doing something wrong.
I would like to ask for help in this matter.
Thanks a lot,
Kinga
Userlevel 2
Badge +5
@kszaf
You can right click the failed push install job and do “View Logs”. This will show you what the install was doing and why it failed.
Another thing you can try is manually installing the Exchange package on the client using the Setup.exe. To do this you can simply access the Software Cache location on the CommServe from your Exchange client and run the Setup application to install the package interactively.
Userlevel 2
Badge +11
H @JamesA thanks for your time, so the installations logs
SP22.41
> 6788 17ac 11/16 09:03:13 3589 Packages selected For Install :Exchange
6788 17ac 11/16 09:03:13 3589 CommServe Cache Location [D:\Program Files\Commvault\ContentStore\SW]
6788 17ac 11/16 09:03:13 3589 GetIsUsingNewDownload() - Use New Download key is set to [true]
6788 17ac 11/16 09:03:13 3589 [SetCSCacheInfo]() - Trying to move to side by side cache.
6788 17ac 11/16 09:03:13 3589 [TransitToNewDownload]() - Staging folder [D:\Program Files\Commvault\ContentStore\SW\CVMedia-Staging\11.0.0\Windows] does not exist, checking regular cache
6788 17ac 11/16 09:03:13 3589 [TransitToNewDownload]() - Regular cache [D:\Program Files\Commvault\ContentStore\SW\CVMedia\11.0.0\Windows] is also empty, skipping the transition.
6788 17ac 11/16 09:03:13 3589 [SetCSCacheInfo]() - Do not need to do clean up or baseline update.
6788 17ac 11/16 09:03:13 3589 [getThreadPoolCount] Initializing thread pool size : 5
6788 17ac 11/16 09:03:13 3589 Thread pool monitor interval [300] seconds, Refresh interval [60] seconds
6788 17ac 11/16 09:03:13 3589 [ComputeRequiredRelAndOsList]() - Unable to get network host name of client Id [-1], use client name [CH2-EX-05.chespa.lan] instead.
6788 17ac 11/16 09:03:13 3589 [ComputeRequiredRelAndOsList]() - Could not get answer file since install directory is empty for client [CH2-EX-05.chespa.lan].
6788 17ac 11/16 09:03:13 3589 [ComputeRequiredRelAndOsList]() - Successfully launched thread with Id [1] for [CH2-EX-05.chespa.lan] to get it’s binaryset name.
6788 17ac 11/16 09:03:13 3589 [ComputeRequiredRelAndOsList]() - Waiting for all the clients threads to complete..
6788 5930 11/16 09:03:13 3589 CVImpersonateLoggedOnUser() - caching user sid [S-1-5-18] for optimizing subsequent impersonate operations for this user
6788 5930 11/16 09:03:13 3589 [GetClientOSType]() - Setting OS id to [3] for client [CH2-EX-05.chespa.lan] having binarysetname [WinX64]
6788 17ac 11/16 09:03:13 3589 [CheckWhetherDownloadNeeded]() - Cache has the media for RelId 16, OSId 3, SP SP22_3184510:UP41_0
6788 17ac 11/16 09:03:13 3589 [CheckAndDownloadRequiredMedia]() - Download is not required.
6788 17ac 11/16 09:03:13 3589 [ReadPackageDetails] Packages.xml location D:\Program Files\Commvault\ContentStore\SW\CVMedia\11.0.0\SP22_3184510_R871\Windows\WinPackages.xml
6788 17ac 11/16 09:03:13 3589 [getXMLDetails]() - Get XML details from [D:\Program Files\Commvault\ContentStore\SW\CVMedia\11.0.0\SP22_3184510_R871\Windows\WinPackages.xml] with input: [D:\Program Files\Commvault\ContentStore\SW\CVMedia\11.0.0\SP22_3184510_R871\Windows\WinPackages.xml] isBinaryXML [NO]
6788 17ac 11/16 09:03:13 3589 [getXMLDetails]() - Get XML details from [D:\Program Files\Commvault\ContentStore\SW\CVMedia\11.0.0\SP22_3184510_R871\Windows\BinaryInfo.xml] with input: [D:\Program Files\Commvault\ContentStore\SW\CVMedia\11.0.0\SP22_3184510_R871\Windows\] isBinaryXML [YES]
6788 17ac 11/16 09:03:14 3589 [SetSidesToBeInstalledOnRCClients]() - Number of software caches involved in this job are [1]
6788 17ac 11/16 09:03:14 3589 Only remote cache’s having status as invalid will be tried for sync.
6788 17ac 11/16 09:03:14 3589 [SyncUAForJob]() - Remote cache list is empty for the syncup.
6788 17ac 11/16 09:03:14 3589 Number of clients in job: [1]
6788 17ac 11/16 09:03:14 3589 [CheckIfInstallRequired]() - Ports numbers are not specified from GUI. checking Whether the machine is already part of CS
6788 17ac 11/16 09:03:14 3589 CheckWhetherClientIsAlreadyPartOfCS() - No Client found with the host name CH2-EX-05.chespa.lan and with the CS release and build number. Install Base..
6788 17ac 11/16 09:03:14 3589 [CheckIfInstallRequired]() - It is a pre install. New client will be installed..
6788 17ac 11/16 09:03:14 3589 ****** New Client = [CH2-EX-05.chespa.lan], ClientId = [-1], Release = [11.0.0], UpdateAgentClientId = [2]
6788 17ac 11/16 09:03:14 3589 Client [CH2-EX-05.chespa.lan] cache source : CommServe
6788 17ac 11/16 09:03:14 3589 No package or update requires reboot as per info on CS, client can reboot (if required) during actual installation
6788 17ac 11/16 09:03:14 3589 [ComputePatches]() - Setting OS id to [3] for client [CH2-EX-05.chespa.lan]
6788 17ac 11/16 09:03:14 3589 SP found in cache [SP22_3184510:UP41_0]
6788 17ac 11/16 09:03:14 3589 [GetInstalledUpdatesListFromDB]() - No updates installed on client [-1]
6788 17ac 11/16 09:03:14 3589 Packages and Updates installed on client:
6788 17ac 11/16 09:03:14 3589 Created lock file [D:\Program Files\Commvault\ContentStore\Deployment\SwCacheLocks\ch3-commserve\SP22_3184510\WinX64\ReadLocks\P6788_J3589.lock]
6788 17ac 11/16 09:03:14 3589 [StartRemoteActivity]() - successfully acquired read lock on cache [ch3-commserve] to copy packages and launch installer on client CH2-EX-05.chespa.lan
6788 17ac 11/16 09:03:14 3589 Sending request to software cache [CH3-COMMSERVE.chespa.lan] to perform base package install on remote client CH2-EX-05.chespa.lan
6788 17ac 11/16 09:03:14 3589 [fnCSUpdateDBJMStatusNew]() - Client status [ QGENERIC_QUEUING_FOR_TRANSFER] set successfully in JMQinetixUpdateStatus Table for client [ -1] [ CH2-EX-05.chespa.lan ]
6788 17ac 11/16 09:03:14 3589 [CCVPatchesUpdateDBServer::dllConnect]() - Starting dll connect in DBServer remoteHostName = CH3-COMMSERVE.chespa.lan*ch3-commserve*8400
6788 17ac 11/16 09:03:14 3589 [CCVPatchesUpdateDBServer::processXMLMessage] Requested Operation on Client succeeded
6788 17ac 11/16 09:03:14 3589 Successfully sent base package install request to client to software cache [CH3-COMMSERVE.chespa.lan]
6788 17ac 11/16 09:03:14 3589 Successfully initiated base package install request for client [CH2-EX-05.chespa.lan]
6788 17ac 11/16 09:03:14 3589 ****** Now Check status of all clients ******
6788 17ac 11/16 09:03:14 3589 Check status started for client [CH2-EX-05.chespa.lan][-1]
6788 17ac 11/16 09:06:44 3589 Waiting for the remote cache syncup threads to be completed..
6788 17ac 11/16 09:06:44 3589 Clients Failed:
6788 17ac 11/16 09:06:44 3589 Client [-1] [CH2-EX-05.chespa.lan] [QINSTALL_FAILED]
6788 17ac 11/16 09:06:44 3589 *******************************************
6788 17ac 11/16 09:06:44 3589 bvSuccess = false, bvFailed = true, bvRestartNeeded = false, bvUnknown = false, bvOperationNotSupported = false, bvSkipped = false, bvPartialSuccess = false, bvMachineRebootRequired = false m_nvJobRetStatus = 1
6788 17ac 11/16 09:06:44 3589 Job Failed.
6788 17ac 11/16 09:06:44 3589 COMPLETE CALLED (JOB Status::FAIL), Job ID = 3589
6788 17ac 11/16 09:06:44 3589 [deleteLockFiles]() - Successfully deleted the lock file D:\Program Files\Commvault\ContentStore\Deployment\SwCacheLocks\ch3-commserve\SP22_3184510\WinX64\ReadLocks\P6788_J3589.lock
6788 1958 11/16 09:06:44 3589 CVJobCtrlLog::unregisterProcess(): successfully removed file [D:\Program Files\Commvault\ContentStore\Base\JobControl\6.788]
Userlevel 2
Badge +5
@kszaf
That looks like the PushInstall.log from the CommServe. That logs is telling me the packages reached the client but the client install failed on the client side.
Can you logon to CH2-EX-05.chespa.lan and in the Commvault\ContenStore\Log Files location can you check the Install.log for the error?
Userlevel 2
Badge +11
@JamesA
From the content I can see the message:
24848 4 11/16 15:04:06 3595 ### ### - Error: Another instance is already installed. Failed to create a new instance as allowMultipleInstances flag is not set.
You will probably have to try uninstalling / wiping everything on the host and trying again, but I prefer to wait for confirmation.
Userlevel 2
Badge +5
@kszaf
Thanks for the log line. This means you already have an instance installed.
If you check in the CommCell Console do you not see a client already named CH2-EX-05 in the list? If you do, then you can simply right click > All Tasks > Add/Remove Software > Install Software like so:
If you dont see the client, it might be a hidden virtual machine client. To show these types of clients, right click on Client Computers > Customize View
You can then enable “Virtual Machines” from the view list options:
Let me know if this helps..
Userlevel 2
Badge +11
@JamesA thanks for your time!
From the CommCell Console level, I cannot uninstall the software - there is no information that something was installed there.
On the CH2-EX-05 host itself, however, the 'Commvault ContentStore' was installed
I uninstalled the package from the operating system side, removed the remnants in C: \ Program Files \ Commvault
I tried to install the package again from CommCell - unsuccessful.
The end result is the same as the last one - from the CommCell side, the installation process has the 'failed' status, the Exchange node is not detected.
Userlevel 2
Badge +5
@kszaf
If you check the Install.log on the exchange node, what was the failed install reason?
Userlevel 2
Badge +11
@JamesA thanks for your time. I check the logs. I see
Error: Failed to ServiceQuery with error :
924  4     11/23 14:56:33 ###  ManagedLogger::SetCLRThreadPoolMaxThreads - CLR ThreadPool's max threads is already set by another thread in the process. maxWorkerThreads = [1000], maxIOThreads = [1000], PID = [9924], ProcessName = [Setup].
9924  4     11/23 14:56:33 ### ### ### - The setup is running in non-bootstrap mode
9924  4     11/23 14:56:33 ### ### ### - ##########################################################################
9924  4     11/23 14:56:33 ### ### ### - ##                         Installation STARTED                         ##
9924  4     11/23 14:56:33 ### ### ### - Media Version:[11.80.220.0], Feature Release:[22], TransactionId:[3184510]
9924  4     11/23 14:56:33 ### ### ### - Exchange E16 installed.  Titanium set to true also
9924  4     11/23 14:56:33 ### ### ### - CommandLine: "C:\CVMedia\setup.exe" /play "C:\CVMedia\CH2-EX-05.base.xml" /silent -quiet -burn.unelevated BurnPipe.{B2BAC39C-FEB8-4D37-95D2-7CF78D8CA2AD} {08B08361-65EF-4265-8A91-5ABE5DEF95A4} 26052
9924  4     11/23 14:56:33 ### ### ### - User input file location: [C:\CVMedia\CH2-EX-05.base.xml]
9924  4     11/23 14:56:34 ### ### ### - Job Id in answer file: [3669]
9924  4     11/23 14:56:34 3669 ### ### - The setup is launched by CHESPA\lapostel-admin with Administrator privilege
9924  4     11/23 14:56:34 3669 ### ### - Showing dialog : CheckLaunchRequirementViewModel .......
9924  4     11/23 14:56:34 3669 ### ### - Machine is running windows OS version 10.0.14393
9924  4     11/23 14:56:34 3669 ### ### - Showing dialog : LanguageSelectionViewModel .......
9924  4     11/23 14:56:34 3669 ### ### - Skip [LanguageSelectionViewModel] in silent install mode
9924  4     11/23 14:56:34 3669 ### ### - Showing dialog : OEMBrandSelectionViewModel .......
9924  4     11/23 14:56:34 3669 ### ### - OEM ID from xml: [1].
9924  4     11/23 14:56:34 3669 ### ### - Showing dialog : LicenseAgreementViewModel .......
9924  4     11/23 14:56:34 3669 ### ### - Skip [LicenseAgreementViewModel] in silent install mode
9924  4     11/23 14:56:34 3669 ### ### - Showing dialog : InstallTypeViewModel .......
9924  4     11/23 14:56:34 3669 ### ### - Showing dialog : InstanceSelectionViewModel .......
9924  4     11/23 14:56:34 3669 ### ### - Instance name from input request: [New].
9924  4     11/23 14:56:34 3669 ### ### - Selected instance: [Instance001].
9924  4     11/23 14:56:34 3669 ### ### - Showing dialog : FeatureSelectionViewModel .......
9924  4     11/23 14:56:34 3669 ### ### - Required packages included by the installer: [File System Core].
9924  4     11/23 14:56:34 3669 ### ### - no database packages are selected. Skip cluster option screen
9924  4     11/23 14:56:34 3669 ### ### - Showing dialog : CheckPrerequisitesViewModel .......
9924  4     11/23 14:56:34 3669 ### ### - Removing VCRedist_2017_win32 as it is not applicable for this OS.
9924  1     11/23 14:56:34 3669 ### ### - Checking if required third-party packages are installed...
9924  4     11/23 14:56:34 3669 ### ### - Showing dialog : GalaxyHomePathViewModel .......
9924  4     11/23 14:56:34 3669 ### ### - Install directory from xml: [""].
9924  4     11/23 14:56:34 3669 ### ### - Install directory from xml is empty, using default install directory: ["C:\Program Files\Commvault\ContentStore"].
9924  4     11/23 14:56:34 3669 ### ### - Showing dialog : ConfigureRolesViewModel .......
9924  4     11/23 14:56:34 3669 ### ### - Port number for CVD is set to [8400].
9924  4     11/23 14:56:34 3669 ### ### - Showing dialog : InstallSummaryViewModel .......
9924  4     11/23 14:56:34 3669 ### ### - Log move to C:\Program Files\Commvault\ContentStore\Log Files\Install.log
9924  4     11/23 14:56:34 3669  ManagedLogger::SetCLRThreadPoolMaxThreads - CLR ThreadPool's max threads is already set by another thread in the process. maxWorkerThreads = [1000], maxIOThreads = [1000], PID = [9924], ProcessName = [Setup].
9924  4     11/23 14:56:34 3669 ### ### - ------------------------ Creating New Instance ----------------------------
9924  4     11/23 14:56:34 3669 ### ### - Showing dialog : PreInstallValidatonViewModel .......
9924  4     11/23 14:56:34 3669 ### ### - Drive [C:\] Space needed [249.66 MB] Available Space[170.56 GB]
9924  4     11/23 14:56:34 3669 ### ### - Showing dialog : ShutdownViewModel .......
9924  4     11/23 14:56:34 3669 ### ### - Error: Failed to ServiceQuery with error :
9924  4     11/23 14:56:34 3669 ### ### - Stopped all Commvault services.
9924  4     11/23 14:56:34 3669 ### ### - Killing all running processes from install directory ...
9924  4     11/23 14:56:34 3669 ### ### - Successfully killed processes for [Python.exe]
9924  4     11/23 14:56:43 3669 ### ### - Showing dialog : InstallProgressForPrerequisitesViewModel .......
9924  4     11/23 14:56:43 3669 ### ### - Removing VCRedist_2017_win32 as it is not applicable for this OS.
9924  1     11/23 14:56:43 3669 ### ### - Checking if required third-party packages are installed...
9924  1     11/23 14:56:43 3669 ### ### - Installing required third-party packages...
9924  1     11/23 14:56:43 3669 ### ### - Apply prerequisites completed ...  Status = 0
9924  1     11/23 14:56:43 3669 ### ### - Third-party package installation completed.
9924  4     11/23 14:56:43 3669 ### ### - Showing dialog : InstallProgressForPackagesViewModel .......
9924  4     11/23 14:56:43 3669 ### ### - Exchange E16 installed.  Titanium set to true also
9924  1     11/23 14:56:43 3669 ### ### - Installing packages...
9924  1     11/23 14:56:49 3669 ### ### - Checking and removing stale MSI with product [File System Core]
9924  1     11/23 14:56:49 3669 ### ### - Started install/update of package: WindowsFileSystemiDataAgentCore...
9924  1     11/23 14:56:54 3669 ### ### - Apply packages completed ...  Status = 0
9924  1     11/23 14:56:54 3669 ### ### - Package installation completed.
9924  1     11/23 14:56:54 3669 ### ### - Update installation is in progress...
9924  1     11/23 14:56:54 3669 ### ### - Please check [C:\Program Files\Commvault\ContentStore\Log Files\UpdateInfo.log] for granular details
9924  1     11/23 14:57:04 3669 ### ### - Update installation completed.
9924  4     11/23 14:57:04 3669 ### ### - Showing dialog : PostFileCopyConfigurationViewModel .......
9924  4     11/23 14:57:04 3669 ### ### - Base path [C:\Program Files\Commvault\ContentStore\Base] is not present in the system PATH environment variable.
9924  4     11/23 14:57:04 3669 ### ### - Adding environment variable [CV_Instance001] = [C:\Program Files\Commvault\ContentStore\Base]
9924  4     11/23 14:57:04 3669 ### ### - Pre Configuring File System Core ...
9924  4     11/23 14:57:05 3669 ### ### - Showing dialog : CompletionExitViewModel .......
9924  4     11/23 14:57:05 3669 ### ### - Starting configuration steps...
9744  1     11/23 14:57:05 ### ### ### - --------------------- Install Configuration STARTED ----------------------
9744  1     11/23 14:57:05 ### ### ### - Exchange E16 installed.  Titanium set to true also
9744  1     11/23 14:57:05 ### ### ### - Skip creating configuration wizard shortcut in silent install mode.
9744  1     11/23 14:57:05 ### ### ### - CommandLine: "C:\Program Files\Commvault\ContentStore\Base\ConfigureClientTool.exe" /play "C:\CVMedia\CH2-EX-05.base.xml" /silent
9744  1     11/23 14:57:05 ### ### ### - User input file location: [C:\CVMedia\CH2-EX-05.base.xml]
9744  1     11/23 14:57:06 3669 ### ### - The setup is launched by CHESPA\lapostel-admin with Administrator privilege
9744  1     11/23 14:57:06 3669 ### ### - Application Culture is set to en-US
9744  1     11/23 14:57:06 3669 ### ### - Showing dialog : CommunicationInterfaceNameViewModel .......
9744  1     11/23 14:57:06 3669 ### ### - Overriding nPreferredIPFamily to 1 based on answer file
9744  1     11/23 14:57:06 3669 ### ### - Dialog:[Client Computer Information], UserAnswer:[Client Name: CH2-EX-05, Client HostName: CH2-EX-05].
9744  1     11/23 14:57:06 3669 ### ### - Showing dialog : FirewallConnectionTunnelPortViewModel .......
9744  1     11/23 14:57:06 3669 ### ### - Encrypted Tunnel is set to https by XML file
9744  1     11/23 14:57:06 3669 ### ### - nFirewallConnectionType is set to 0 by XML file
9744  1     11/23 14:57:06 3669 ### ### - Showing dialog : RunFirewallDaemonViewModel .......
9744  1     11/23 14:57:06 3669 ### ### - Skip Starting FirewallDaemon for silent and play mode
9744  1     11/23 14:57:06 3669 ### ### - client groups read from the user input: [[CH2-NTNX-CLUSTER2] ].
9744  1     11/23 14:57:06 3669 ### ### - Using storage policy SP-SYS-DDB/INDEX-7D from the user input.
9744  1     11/23 14:57:06 3669 ### ### - Showing dialog : LocalConfigViewModel .......
9744  1     11/23 14:57:06 3669 ### ### - Skip updating SQL server startup parameters as database packages are not selected/ installed.
9744  1     11/23 14:57:06 3669 ### ### - Adding network applications to firewall exclusion list.
9744  1     11/23 14:57:06 3669 ### ### - Configuring File System Core ...
9744  1     11/23 14:57:06 3669 ### ### - Executing pending applications for Updates Installed
9744  1     11/23 14:57:06 3669 ### ### - Update installation is in progress...
9744  1     11/23 14:57:06 3669 ### ### - Please check [C:\Program Files\Commvault\ContentStore\Log Files\UpdateInfo.log] for granular details
9744  1     11/23 14:57:06 3669 ### ### - Warning: ["C:\CVMedia\BinaryPayload\LooseUpdates\InstallUpdates.exe" -doNotUpdateDB -nostartsvc -silent -vm Instance001 -delayedreboot -ignorePendingFileOp -galaxyinstall   -jobid 3669  -cvinstaller ] exit code 2
9744  1     11/23 14:57:06 3669 ### ### - Update installation completed.
9744  1     11/23 14:57:06 3669 ### ### - Finalizing installation ...
9744  1     11/23 14:57:06 3669 ### ### - Showing dialog : SIMRegistrationViewModel .......
9744  1     11/23 14:57:07 3669 ### ### - Translated exit code [Succeed] to job status [1140850873]
9744  1     11/23 14:57:07 3669 ### ### - Created PreImageModeFile for registration of client.
9744  1     11/23 14:57:07 3669 ### ### - Set auto-register value to 1.
9744  1     11/23 14:57:07 3669 ### ### - Showing dialog : StartupViewModel .......
9744  1     11/23 14:57:08 3669 ### ### - Start service GxFWD(Instance001) ...
9744  1     11/23 14:57:08 3669 ### ### - Service GxFWD(Instance001) started.
9744  1     11/23 14:57:08 3669 ### ### - Start service GxCVD(Instance001) ...
9744  1     11/23 14:57:09 3669 ### ### - Service GxCVD(Instance001) started.
9744  1     11/23 14:57:09 3669 ### ### - Doing startup steps for File System Core ...
9744  1     11/23 14:57:09 3669 ### ### - Explorer plugin is not disabled/unregistered by installer, skip launch CBFS driver.
9744  1     11/23 14:57:09 3669 ### ### - Waiting on client registration status from CommServe...
9744  1     11/23 15:07:39 3669 ### ### - Client registration did not complete in expected time. It will be re-tried by Communication services.
9744  1     11/23 15:07:39 3669 ### ### - -------------------- Install Configuration COMPLETED ---------------------
9744  1     11/23 15:07:39 3669 ### ### - Showing dialog : ConfigurationCompleteViewModel .......
9744  1     11/23 15:07:39 3669 ### ### - Removed [Configuration Wizard] shortcut.
9744  1     11/23 15:07:39 3669 ### ### - Quit silent install with exit code Succeed
9924  4     11/23 15:07:44 3669 ### ### - Quit application with code: Succeed.
9924  4     11/23 15:07:44 3669 ### ### - Setup is shutting down with exit code Succeed ...
9924  4     11/23 15:07:44 3669 ### ### - Installer registry will be cleared as Install operation completed successfully
9924  4     11/23 15:07:44 3669 ### ### - Translated exit code [Failed] to job status [1140850839]
9924  4     11/23 15:07:44 3669 ### ### - Clearing Configuration installer registry
9924  4     11/23 15:07:44 3669 ### ### - Clearing Galaxy installer registry
9924  4     11/23 15:07:45 3669 ### ### - Quit silent install with exit code Succeed
9924  4     11/23 15:07:45 3669 ### ### - ##########################################################################
9924  4     11/23 15:07:45 3669 ### ### - ##                       Installation EXITING (0)                       ##
Userlevel 2
Badge +5
@kszaf
Bit strange this one.. It looks like communication with CommServe had issues so client registration failed, but then install completed and it failed the job:
If you check on the client is the Commvault software installed and services started?
Do you see the client listed in the CommServe and can do a “Check Readiness” does that work?
It might be worth trying also to uninstall the Commvault software from the client, delete the Commvault folder afterwards. Then in the CommServe you could delete any clients you see of the same name. Just double check before you delete the client that there is no Virtual Machine backup jobs on that client you want to keep.
Userlevel 2
Badge +11
Thanks @JamesA
The software seems to be installed and running on the client:
The ‘Check Readiness’ report of 1 client – CH2-EX-05 – is also attached.
In CommCell it is listed as a ‘grey’ client:
The Exchange DAG also doesn’t discover any Exchange Server clients.
Should I proceed with uninstalling the software, removing the client and adding it again?
Userlevel 2
Badge +5
@kszaf
Looks like the client in the CommServe Console is not configured which is why it is grey.
Can you right click the client > All Tasks > Reconfigure
You should see the client then not be grey any more. Let me know if this works.
You dont need uninstall or reinstall anything.
Userlevel 2
Badge +11
Using the Reconfigure option turned the client ‘blue’:
So that’s a start.
To make sure everything’s setup clean I uninstalled the software from the client side and installed it again (via CommCell).
The installation keeps failing as before, the software seems to be on the clint side though (as it was the case before).
I can use the Check Readiness option per Client now (since it’s ‘blue’), that returns this message:
Userlevel 2
Badge +5
@kszaf
There seems to be something unique about your environment here we will need to investigate more. It sounds like the client is having issues registering with the CommServe.
I feel it would be best at this stage you open a Support Ticket and let us have a remote session with you to check things further.
Agreed with @JamesA .
Share the case number here once you do so we can track it :nerd:
Userlevel 2
Badge +11
Thanks @Mike Struening and @JamesA i check logs again, and if still not found it come back wit case number.
Cheers,
Kinga
Thanks for the update Kinga!  Keep us posted :sunglasses:
