Is there a way to backup the REPLICA copy of vSphere Replication?
Best answer by Damian Andre
View originalHi,
View originalHi
Unfortunately, I don't think so. It has been some time since I have looked at this, but vSphere replication does not attach the disks to the replica VM until the time of failover. So you essentially have a VM with no data attached, and nothing to protect. You may want to consider Commvault to replicate the VM instead, and you have three options to do that:
Thanks Damian… that’s what I thought. I was hoping for something different.
Yes… I’m testing the live sync functionality at the moment
Thanks again
There is the VMWARE product for replication using vSphere Replication
The options given by Damian is done via Commvault
