I’ve looked at the list of destinations for cloud library and didn’t find Azure Gov. Cloud. We currently use Azure but will move to Azure Gov Cloud.
Can I create a Cloud library in Azure Gov by just choose Azure and change the url? Or isn’t Azure Gov Supported as destination?
BR
Henke
Best answer by Prasad Nara
