Cloudapps not showing under protect section
  • 14 March 2021
  • 94 views
Badge +1
Hi.
I am new to commvault and i deployed cloud control (all in one) in Azure. After initial settings, when i navigate to protect section, i couldn't find application section at all.
In the guided setup page, i could see cloudapps with tick enabled, but when i click it. Its not navigating me to cloudapps section. Is this a bug or am i missing anything here?
Cloud control version : 11.22.0
Best answer by ak2 14 March 2021, 10:25
Userlevel 1
Badge +5
Hi Prabhu,
edit the Navigation Pane.
you find this in Manage → customization → Navigation.
Select Permissions for Cloud Apps.
best regards,
Andreas
Badge +1
Hi Andreas, thank you so much for the help. It resolved my issue :)
