Commserve Email Settings
  • 19 February 2021
  • 955 views
Userlevel 2
Badge +7
When changing the Commserve Email configuration is there a service that should be restarted to ensure the new configuration becomes active? I have recently updated the email configuration however the emails are still using the old configuration (From Address, SMTP Server Address).
Thanks in advance for any response.
Best answer by dude 19 February 2021, 16:27
Badge +15
Hi @Tom Evans
If after changing your settings you still cant see the new settings being applied try restarting the Server Event Manager Services in your CommServer.
Refer to: https://documentation.commvault.com/commvault/v11/article?p=3818.htm
Userlevel 2
Badge +7
Thanks @dude, restarting the Server Event Manager Services looks to have done the trick.
