Commvault logon SSO stuck
  • 25 November 2021
  • 438 views
Badge +14
I have enabled SSO on commserve. Today when I try to connect, it is stuck at :  Logged in. Initializing UI
I have restarted services.
How to force to connect in local mode to troubleshoot ?
Thanks !
Best answer by Sebastien Merluzzi 25 November 2021, 13:26
Badge +14
Hi @Bloopa,
You can press cancel and then it will give you the option.
Please check webconsole.log and webserver.log.
Sebastien Merluzzi
Badge +9
Please review EvMgrS.log from the Commserve during logon attempts.
Badge +14
Hi @Bloopa,
Sebastien Merluzzi
I have loggued with local admin then logout then log in again with sso and now it is ok !
Thanks to all !
