Commvault Report - Populate CommServe Dashboard only for migrated clients/media agents
  • 14 February 2021
  • 11 replies
  • 126 views
Userlevel 1
Badge +7
Hi All,
We are completely installing Commvault setup from scratch for 100+ sites. I am looking your assistance to generate the report as per mgmt report.
I need to populate the data in CommServe Dashboard only for migrated clients/media agents. For example I have one remote site and the report related the sites such as Disk Library growth Media Agent load, SLA , Job Summary and etc.. should be included in the commvault reports after migration.
As per my understanding, I can exclude particular client  or group from SLA report. But can I include only particular group in the report?
Mani
Best answer by Manikandn 25 March 2021, 08:36
Badge +2
Hi Mani,
Is there a particular dashboard/ report you are currently looking at that you wish to present to management? Is it the SLA report or any other?
Userlevel 5
Badge +10
Hi All,
Mani
I have not looked at the specifics of the report to confirm if you can only do an Exclude and not Include - but if you need something quick it is possible to create an Automatic Association called ‘Not Migrated Clients’ with a Rule Group ‘Associated client group’ where ‘not equal to’ GroupName=’Migrated Clients’.  Then when you run the report, choose ‘Not Migrated Clients’ as the exclude filter.
Userlevel 1
Badge +7
Hi All,
Mani
Hi Antony,
I can exclude it manually during report generation, but I am looking in the commvault dashboard view
Userlevel 1
Badge +7
Hi Mani,
Hi Kaushik,
I am good go with all the report if possible.
If not I am more looking on the Health Report and SLA Report.
Mani
Hi All,
Mani
@Manikandn , have you tried @Anthony.Hodges ‘s suggestion?  This should do the trick.
Userlevel 1
Badge +7
@Mike Struening , For manual report generation, it works perfectly. But, for populate value in worldwide dashboard, Couldn’t achieve it
@Manikandn , appreciate the confirmation.  I’ll look around internally and see what I can find.
@Manikandn , appreciate the patience!  Dev confirmed back that this is not possible in a dashboard, though encouraged me to create a CMR.
Would you be able to write up a detailed description of what you’d like to accomplish and how?  I can submit the CMR for you and share back the number.
@Manikandn , gentle follow up on the CMR.  I can enter it for you, though I’d like your outline on exactly what this should look like.
Userlevel 1
Badge +7
Hi Mike,
I created a CMR 313093.
Mani
Thanks for the update, @Manikandn !!
