We are putting in a new commcell and starting completely fresh and don’t want to import anything from the old but we will be backing up the same clients as the old commcell.
Are any client configuration changes (client Win registry, config files etc) required if the new commcell wants to backup the client which was previously backed up by another commcell?
The old commcell domain will remain for a while for restores and the conversion will be staggered. The idea is if there are changes required on client they will have to flipped back to the original for restores.
The old commcell agent software is reasonably up to date and we trying to avoid installing two agents on the same client.
Thanks Jim
