Creating pseudo-client for RHEV (http vs https)
Badge +8
  • Commvault Certified Expert
  • 62 replies
Hi Guys,
I am creating the RHEV pseudo-client with the Customer.
We have noticed that during creating RHEV pseudo-client, Commvault uses port 80 (http) to comunicate with RHEV Manager.
Port 80 (http) is blocked by the firewall. They use only https (port 443) in the environment due to some safety restrictions.
Is any way to force Commvault (VSA) to use port 443 during creating RHEV pseudo-client?
Rgds,
Kamil
Best answer by Aplynx 15 October 2021, 19:27
Badge +13
Hello @Kamil W ,
What version of Commvault FR and MR are you using here please?
The reason for asking is that some recent MR’s include a patch to resolve the configuration issue when Port 80 is blocked:
Maintenance Release 11.24.2
Maintenance Release 11.23.17
Maintenance Release 11.22.32
Michael
Badge +8
Hi @MichaelCapon ,
It’s definitely FR20. I’ll ask the Customer about version of Maintenance Release.
I’ll let you know ASAP.
Rgds,
Kamil
Badge +8
Hi again,
CS is running 11.20.67
I cannot see any mention about the issue for FR20.
https://documentation.commvault.com/11.22/assets/service_pack/updates/11_20_67.htm
Any ideas?
Rgds,
Kamil
Badge +13
Hi @Kamil W ,
I am checking this and will get back to you.
Michael
Badge +8
@MichaelCapon  Sure, I am looking forward to any news from you.
Rgds,
Kamil
Badge +13
Hi @Kamil W,
If your customer does not have any plans to move to the above stated versions, can you raise a case with Support? - We may be able to request this for back port to FR20.
Thanks & Kind Regards,
Michael
Badge +8
@MichaelCapon  Many thanks!
The Customer decided to upgrade CS to 11.22.45
I’ll let you know, how it goes ASAP.
Rgds,
Kamil
Hey @Kamil W , gentle follow up on this one.  any word from your customer?
Badge +8
Hi @Mike Struening !
Yes, I had a remote session with the Customer yesterday.
They upgraded CS to 11.24.7. However, once port 80 is blocked, backup of RHEV is not working.
It seems like port 80 is needed to initiate the connection, then Commvault is already using port 443 to backup the data. That’s what they see in the Firewall GUI.
Any ideas how to resolve this issue? They need to use port 443 (https) due to some safety policys.
Rgds,
Kamil
Userlevel 5
Badge +10
Kamil,
With 24.7 installed, that would include hotfix 3030 (part of 24.2). If this is also installed on the proxy\access nodes for RHEV, when the initial denial happens on port 80 (http) a certificate should be generated either way and retried on port 443 (https). If 24.7 is on the proxies and we’re not seeing this behavior, please open a support incident for review.
Badge +8
Hi @Aplynx ,
Many thanks for your reply.
As I remember VSA is running 11.20.x.
Once the Customer updates VSA Proxy, I’ll let you know how it goes.
Rgds,
Kamil
Hi @Kamil W , following up to see if the customer has updated the proxy yet.
Badge +8
Hi guys!
The customer has finally upgrated the proxy. Everything’s working as expected now.
Thank you for your help!
Rgds,
Kamil
Sweet, thanks for the update!!
