I’m looking for a way to disable pre- and post-processes to avoid execution on a client.
To increase security / hardening.
Best answer by Damian Andre
View originalHello,
View originalHi Sergej,
The pre and post process can be disabled by prepending -- to the command.
Example prescan command is C:\command\pre.bat
Prepend the command with -- as below, the phase will be skipped.
--C:\command\pre.bat
Anant
Thank you
Such kind of feature would increase security of critical nodes, e.g. an admin would not be able to execute a script/file he has restored on the client before.
Hey
More details here: https://documentation.commvault.com/11.24/expert/8298_client_permissions.html
Configure a pre-process or post-process.
Add a pre-process and post-process for data recovery operations.
Remove a pre-process and post-process for data protection/archive operations.
