Error upgrading from sp17 to sp20
  • 21 July 2021
  • 100 views
Userlevel 2
Badge +11
We want up from sp 17 to 20.
At the very beginning of the procedure we ran into the problem of communication between nodes.
Here are the screenshots:
Best answer by kszaf 17 August 2021, 10:55
Hey @kszaf !  I noticed in the dev update regarding your other thread’s incident that there was something regarding your Remote Cache.  That MAY be at play here, though I’m going to tag in some of our internal folks.
Badge
Hi@kszaf
This does look like the issue in your other incident is coming into play here.
Can you disable the Remote Cache on the Active Nodes then do a download and install job  to the Commserve.
If this does not help, let us know.
Userlevel 2
Badge +11
Thanks @Mike Struening , @Bill A
I don’t now how to do that - disable remote cache and active nodes and upgrade again?
Userlevel 2
Badge +11
@Bill A in configuration we don t use remote cache
Badge +6
Hi
@kszaf
Please review the instructions I sent you for the case ending in -283 you have open with support
You are indeed using remote caches but the configuration is not correct, this is causing issues with the updates being applied on the Commserve and other instances
Userlevel 2
Badge +11
Thanks a lot for help! We decide that the best solution will be reinstall environment.
