Good Afternoon,
Whenever a colleague logs onto one of our laptops they have multiple windows popup and disappear including Commvault edge monitor as it starts. Is it possible to hide the loading screen?
John
Best answer by Jim P
View originalGood Afternoon,
John
View originalHi
So far, all I can find is this setting to hide it in the shortcut menu, though it sounds like it might also hide the notifications as well:
https://documentation.commvault.com/commvault/v11/article?p=41431.htm
I’m going to ask some of our internal folks to confirm.
Hi
Yes running that setting does not help as it completely removes Edge monitor.
Thank you.
Is the startup screen a splash screen or one of those blank command windows?
Hello
There are no options to hide this splash screen. Only to hide the whole app like the link in the previous response. I verified with the Dev Edge Team.
Let us know if you have any other questions.
Thanks Jim, that is a shame.
Does Commvault have a development request board to request functionality like that?
We don’t have one…...yet. It’s an option on this community, though we want to ensure it’s lined up with the right folks first.
Either way, you can request a CMR here and we can add it in for you (I’ll consider the above the request).
We will respond back with the CMR number.
