How to add Huawei Fusion cloud open stack with identity access management instead of keystone??
  • 5 October 2021
  • 246 views
Badge +2
Best answer by Chi Miao 29 October 2021, 22:04
Hello @Mansour Samir , thanks for the post!  Can you clarify a bit on what you are trying to accomplish?
Hi @Mansour Samir , gentle follow up on this post.
What is it you are looking to accomplish?
Userlevel 2
Badge +8
Hi everyone
i ve the same question.on  HCS 6.5 environnement.
I deploy a FREL template proxy node from cloud.commvault.com.
when i try to deploy openstack client, i’ve a communication error with the frel.
CVD port are open on FREL ( i can cvping since commserve )
on HCS there no keystone module. So do we connect directly to service center ?
Regards
Userlevel 2
Badge +4
Hello All,
With Openstack, their Idenity management service is called a Keystone, Please see their documentation below for explanation.
https://docs.openstack.org/newton/admin-guide/identity-management.html
https://access.redhat.com/documentation/en-us/red_hat_openstack_platform/16.0/html/security_and_hardening_guide/identity_and_access_management
