How to create GridStor®️ (Alternate Data Paths)
  • 10 June 2021
  • 1071 views
Userlevel 1
Badge +6
Hello All,
I would like to know if there is a procedure how to do GridStor®️ (Alternate Data Paths).
I want to link a secondary Media Agent to primary(first) Media Agent.
I want that the Round Robin will work with both of the Media Agent.
Best answer by Blaine Williams 10 June 2021, 16:31
Userlevel 5
Badge +8
Hi @Jean-Paul
Everything you need to know is fully documented here with examples.  Please start here and go through it.
https://documentation.commvault.com/commvault/v11_sp20/article?p=10842.htm
Direct link to Alternate paths for primary copies
https://documentation.commvault.com/commvault/v11_sp20/article?p=10847.htm#o10855
Direct link to Alternate paths for secondary copies
https://documentation.commvault.com/commvault/v11_sp20/article?p=10847.htm#o10858
Userlevel 1
Badge +6
Thank you, I’ll read the articles and notify you.
Hey @Jean-Paul !  Following up to see if you had any additional questions on this one.
