How to fetch Backup Duration Trend via Job Summary/shortcut
  • 26 July 2021
  • 9 replies
  • 109 views
Badge +1
I have to fetch a monthly report where for example, Agent Type Virtual Server. For this agent I’ll fetch the Job historyfor each day and will apply sorting descending on Duration column. Then manually enter the duration in my report.
For this, is there a shortcut from Reports or some other option? Where I can fetch the highest duration by agent type for a range of dates. For each date highest duration. Like we have
Best answer by B*star 31 July 2021, 19:04
Badge +15
@MFasulo - do we have a built-in report for command center that might cover this, or more of a custom report?
Badge +1
It’s a custom report.
This is how we’ll be representing it to customer.
Badge +15
Ah got it - yes I was wondering if we had a close enough in-built report that you could modify using our custom reports feature
Badge +1
First issue will be to fetch the details, from reports, We can’t get the Duration column . Which is a must.
I got a manual solution yesterday, to fetch the Job history of Virtual server agent and then save it as excel. Remove unnecessary columns and filter out desired data. It’s time saving. Easiest so far.
I was hoping for something more time saving, but we can work with this out for now.
Thanks Damian btw.
Badge +11
Hello !
I would be also interested in such a report, without having to use some 3rd party tool :-)
Badge +1
Hello @Laurent, You’ll only require Commvault application and EXCEL.
This report will allow customer to review the performance of the backups running on Commvault by agent types.
In our case, let’s take Virtual Server agent. I’ll fetch backup history from 1st to end of the month. Then i’ll save it by
Right Click any column of backup history>>Save
It will be saved as a MS Excel 97(xls) file. Open the file, keep necessary column like duration, start time, end time, etc. and remove rest. Then:
Insert two columns after start time>select whole Start Time column>go on Data menu>Click Text to Column>
This will Seperate date and time from Start time column. Convert this new start time date column to a different format(left column in below image).
Remove the other two columns after start time. Now insert another column to get the duration in minutes. To do so use a formula =<selected cell>*1440(1440=24hr * 60mins)
Press enter. Data might be in decimals so change it’s format to whole number from “Format Cells” Option by selecting whole new Duration column.
To fill same data with applied formula for whole column, simply double click the plus icon at the end of the cell.
Now you can apply sort descending on this duration column, and apply filter on start time column. Start selecting the date you want the highest duration for. And enter it in your original “Backup Success Trend” Report.
Threshold will depend based on your production hours and from the schedule start of the agent’s jobs. Create a graph from this table. And you can share the graph to customer.
Hope this info might be useful to you or someone else.
Badge
Kindly check if below query helps you. You can modify according to your environment needs.
you can run this query from ssms or workflow or custom report.
declare @start_day as date
declare @end_day as date
set @start_day = '2021-07-28' --Date edit should be in same format
set @end_day = '2021-07-30'   --Date edit should be in same format
select distinct CONVERT(date, startdate) as 'Date',
max(convert(varchar(8),dateadd(S, durationunixsec,'1970-01-01'), 108)) as 'Duration',
idataagent from CommCellBackupInfo
where startdate >= @start_day and enddate >= @start_day
group by CONVERT(date, startdate),idataagent
order by CONVERT(date, startdate) DESC
Badge +1
@B*star I’m not familiar with SSMS. Can you please let me know it’s full form.
This code looks promising, I might wanna give it a hit.
Badge
  • Open ssms and pass the credentials
  • expand ‘databases’ → find “CommServ” database → right click and select “new query”
  • New tab opens with blank space. We can paste the query there and execute it (Shortcut button : F5). After successful process completion of query, results will be displayed.
updated query :
set @end_day = '2021-07-31'   --Date edit should be in same format
where startdate between @start_day and @end_day
