Installing HyperScale (HS) with Secondary CS. My primary Index and DB located on separate drive letter (Ex: D:\ & E:\), but sec. CS on HS built with only C drive . CS LiveSync recommends that index & db location on pri and sec must be same.
So how I can get an additional drives on sec. CS vm hosted on HS?
Best answer by Damian Andre
