Hi There.
I am searching for technical resources on how we setup an air-gapped environment.
The idea is to have an isolated HSX cluster that we air-gap from the production HSX cluster and used only for Aux Copies long retention.
I checked the online documentation and the internet on how CV achieve this with no luck.
I want to use a VM as a network gateway proxy with blackout window and network topology. I just didn't find how we can automatically shutdown and power up the VM to isolate the air-gapped environment.
Searched for workflow but couldn’t find anything relevant.
Anyone did this before and if so how was it done ?
Abdel
Best answer by Abdellatif AITELBACHA
