Intellinsap:Backup copy scheduling
  • 14 September 2021
  • 517 views
Userlevel 2
Badge +7
I am trying to make sure that all the backup copies finsih successfully without making the overall media agent slow.
https://documentation.commvault.com/11.24/expert/101443_turning_off_parallel_backup_copy_capability.html
I have Subclients 1,2,3,4,5,6 datastores going to SP copies (snap, disk, tape).
I want to make sure that the backup copies run serially. So have created a schedule to start the backup copy job automatically every 120 minutes.
Do I need the above key or the backup options setting → No of Jobs to Run: No. of Simultaneous Jobs to run =1 > Run all the backup copy jobs serially?
Will this also affect the synthetic fulls backups so that they are triggered one after the other every 2 hours?
Best answer by Dan White 14 September 2021, 15:46
Hi @neuwiesener !
This setting should affect ANY backup workflow from running if another one is already doing so.  I would expect Synth Fulls to be included.
I’ll ask if anyone can confirm.
Edit: @Dan White confirmed I was mistaken!  Synth Fulls not affected.
Badge +8
Hello @neuwiesener
You should be fine the way it is configured without the key.
Additionally, this will not affect any synthetic full operations!
Userlevel 2
Badge +7
https://documentation.commvault.com/11.24/expert/101443_turning_off_parallel_backup_copy_capability.html I appears that there are parallel backup copies that are running despite this setting. Not sure if it is coming into effect! I set it on the commcell as it cannot be added on the vsa pseudo client.
@neuwiesener , I’ll talk to @Dan White and see what the expectation is here….if this is intended to affect the client side, then it might not work for your needs.
@neuwiesener , apologies for the delayed response.  How are things running?  Based on @Dan White ‘s advice, Synth Fulls will not be impacted,
