Kill the Commvault jobs automatically if it is in waiting/pending state
  • 17 June 2021
  • 7 replies
  • 3430 views
Userlevel 1
Badge +7
Hi Guys,
I want to automatically kill the jobs in job controller, if it is waiting/pending state for more than 24 hours.
I am aware that CV having the feature and it can be enabled under control panel > Job management > Job restart (tab).
But the pain area is, we need to enable the option for 30+ job types by individually.
Do we any mechanism (workflow/qcommend) to enable the “Total Running Time” alone for all the job types at one shot.
Manikandan
Best answer by Hemant Mishra 21 June 2021, 13:08
Badge
Manikandan
I have asked our Development team if it is possible to enable Total Running Time for the entire Commcell. I will update when I hear back from them.
This may or may not help you, but the Total Running Time can also be set at the Schedule Policy level. If you edit a scheduled job within the Schedule Policy (incr, Full, Synthetic Full...) and go to the Advanced Button->Job Retry Tab, you will see the option to set a total running time for that particular job schedule. This will apply to all subclients associated to this Schedule Policy for that particular type of backup.
Badge +2
@Manikandn ,
Jobs with pending state can be controlled with a commcell wide additional setting.
Below is additional setting to automatically kill laptop jobs.
https://documentation.commvault.com/additionalsetting/details?name=%22JMMaxAllowedClientOfflineTimeLaptop%22&id=2266
There is similar setting for server also.
In addition, total running time can be configured at the schedule level also. So withone configuration setting, jobs with all agents associated with the schedule get covered.
Hemant
Userlevel 1
Badge +7
@Hemant Mishra ,
Thanks for your response and applied the value, but it haven’t killing the jobs as now.
I assume, the values are in sec and I entered 21600 (6 hours). Do I want to consider any other factors?
Mani
Userlevel 1
Badge +7
Manikandan
Hi Bill,
Thanks for your response, awaiting some valuable input from Dev team.
Mani
Badge +2
@Hemant Mishra ,
Mani
Mani,
The configured value is in minutes. So please fix the value accordingly. Also we need to restart Jobmanager service after making this configuration change.
Hemant
Badge +12
@Manikandn ,
Hemant
Hi @Hemant Mishra ,
For a some reason, I couldn’t retrieve the parameter. Is the parameter still named “JMMaxAllowedClientOfflineTimeLaptop” ?
Kind regards.
@Commvault Engineer , make sure you are picking the right category:
https://documentation.commvault.com/2022e/expert/6306_terminating_pending_backup_jobs_when_client_is_unreachable.html
Property
Value
Name
JMMaxAllowedClientOfflineTimeDesktop
Note: For laptop clients, the JMMaxAllowedClientOfflineTimeLaptop additional setting is enabled by default. When the laptop is unreachable for seven days, the pending backup job is committed. If no data was backed up, the backup job is automatically killed.
Category
CommServDB.GxGlobalParam
Type
INTEGER
Value
The number of minutes the job should remain in a pending status. The value that you enter must be greater than the job retry interval.
For example, enter 90 if the backup job should remain in a pending status for 90 minutes before the Job Manager kills it.
