Library cleaning tape procedure
  • 25 August 2021
  • 657 views
Badge +13
The customer has purchased a tape library Fujitsu LT20.
Is there an automatic tape cleaning procedure?
Best answer by dude 25 August 2021, 14:34
Badge +15
You can schedule the cleaning on a regular basis as needed.
Refer to:
Schedule Drive Cleaning: https://documentation.commvault.com/commvault/v11/article?p=10118.htm
Badge +13
Hello @dude
I will see and make this configuration on the customer.
Thanks.
